Failed Remote Start, Check Engine Light
Old Mar 19, 2021 | 03:22 AM
TShifty's Avatar
Default Failed Remote Start, Check Engine Light
Hello everyone,
I just got a 2014 Jeep Wrangler Rubicon about a month or so ago. This morning, I went to remote start the Jeep and it failed. When I started it up, I had a check engine light on (yellow, no flashing). I think I had my windshield wipers on from where it was raining last night, and possibly that caused the remote start to fail and have the ECU send an error? I am hopefully going to check the code when I get off from work today but I was just curious if anyone else has ever had this issue. I believe that the remote start is factory btw, and I’ve already checked the gas cap to make sure that is on tight.
Old Mar 19, 2021 | 06:33 AM
Jeff Pillsworth's Avatar
Remote start will always fail if the check engine is on. Get the code and solve the issue then your remote start should be fine.
Old Dec 27, 2023 | 12:11 PM
Shutterhawkz's Avatar
I had the same problem, Turns out it was my gas cap, Working fine now.
