Fender ? marker lights
hey guys, i was trying to remove my front fender and i can not figure out how to unplug the light, i removed it form the actual fender but cant find the release button of the ofther side of the wire. thanks
thanks, but not quite what i was looking for, i got the light unplugged from the fender so it is hanging. but the directions say to "3. Disconnect the ends of the jumper wire harness (3) from the front side marker/repeater lamp bulb socket and from the engine wire harness." and i can not find the release button.
Originally Posted by KyleReikowsky
and i might be calling it the wrong thing, but im almost positive it unplugs becaused you have to disconnect it to reinstall after market fender flares
I unplugged mine last night. I couldn't find the tab either. I just stuck a flat head screwdriver in there, pushed in then pulled out. (Save the TWSS.) I couldn't get my light covers off of the stock flares, so I just pulled the entire set of wires until I get new covers. They should slide off of the mount by pulling down on them. Do this before using the screwdriver.
Hope this makes as much sense here as it did in my head.
