flashpaq,htypertech,predator, or trinity????
Ok im looking for a programmer for my new 2010 Jeep.. I read all kinds of things about them but have no idea which one to get.. dont worry about cost as much as features..
if there are some that I missed that will do what I want to do then let me know and i'll look into them...
here are the main things i am looking to do let me know which programmer will do it or not
im even open to the idea of a PC-based programmer as well , it does not have to be hand-held..
1] turn my electric engine fan on at a cooler temperature.. as well as go to high speed at cooler temperature...
2] change the SHIFT QUALITY of my automatic transmission.. - it shifts just way to smooth and mushy for me.. id like to have a firmer shift feel
3] hold the lockup converter engaged longer and stay in over drive longer before it hunts out...
4] hold the lockup converter engaged when I pull my foot off the accelerator.. as it is now the lockup disengages and then re-engages everytime you feather the pedal
5] adjust my SHIFT POINTS... when the transmission shifts up or down...
6] gain a little more power through the use of a High octane engine tune.
be able to read out trans temp, engine temp, etc (perhaps i need to install an aeroforce for this)..
--- things i wish a programmer would do.. but havent found one yet.. ---
1] adjust electric fan on / off in relation to A/C head pressure
2] adjust A/C on/off in relation to evap temp probe reading..
3] adjust headlight off delay
4] adjust RAP (retained accessory power..) - be able to disable it with doors off, yet re-enable it for when doors are on.. not just turn it off forever..
5] be able to adjust battery rundown protection timer (how long lights and interior lights stay on with doors open after jeep is turned off)...
-Christopher
-Christopher
