Fog Light Hell - Help
Have had my new JK for about a week and just picked up PIAA 520s. I'm pretty handy but have never installed aftermarket lights. I would greatly appreciate if someone could answer a few quick questions ...
- Where is the best place to enter the interior cab from the engine compartment? I looked for about 10 minutes and can't find a good spot
- I would like the fogs to have power when I turn on the parking lights. Which existing power source should I splice? What color is the wire?
- Best place to mount the relay box and interior switch
- Best place to mount the interior switch
2 - This one, I'm not sure of - sorry.
For my driving lights, I spliced into my hi beam wire - grey/white wire on the pass side headlight.3 - Here is where I mounted the switch for my driving lights. I ran the wires through the hole I mentioned above on the driver's side (I pulled out the plastic side plate and ran the wires under the steering wheel - that plate comes out also - and routed the switch wire up along the gap along the side of the steering wheel)
Hope this helps.
JD
Thanks for the info. Was able to run the wires from the engine bay to the interior. However, I am at a loss as to where to access a power source for the lights and where to mount the relay box.
JD
