Fog lights into daytime running lights
Fog lights into daytime running lights. Has someone don this to a 2008 jk ? If so can you tale me how to wire it. Thanks
I believe you can do this with an AEV Procal without having to rewire anything
Originally Posted by mark jk
(Post 2339971)
I don't know about the Pro Cal. So this may be true. |
Originally Posted by JK-Ford
(Post 2339992)
So basicaly you want the fog lights on anytime the vehicle is running and the headlights are not on?
Originally Posted by Kevlarjk
(Post 2340082)
U have to wire both sides seperatly. Here is a little diagram
Yes that is right. I would like to run them anytime the jeep is running. I do not have a Pro Cal. If someone know how to wire it that would be good. Thanks |
Dont hack into your wranglers harness unless you need to. The AEV Procal will accomplish it for you.
Just seen your post after I had writen mine. You have a good safety point. Now the OP can choose.
To do this mod, you will be required to cut the wires going to the foglights. And reconnect them to a new harness. The tricky part is finding something to trigger the relay when only the engine is running and nothing else is turned on. I have seen another thread where someone else has accomplished this. But I wasn't intrested enough to learn exactly what he did. So, I'm going to prepose that you use any accessory circuit to trigger the relay. Only problem with this arrangement is that the foglights will come on anytime the key is in the accessory position. I have a couple of drawings for you. But you will have to make a couple of alterations to these drawings. This drawing will give you both OEM function or foglights anytime the accessory circuit is activated. Cut the wireing to the foglights. Reconnect the foglights to terminal #87 of the relay. Reconect the foglight feeder wires to the "OEM Circuit" in the drawing. With the three position switch in the up position, the fogs will work normaly. Switch in middle position " always off". Switch in lower position, foglights will come on anytime the accessory circuit is activated. http://i822.photobucket.com/albums/z...Schemattic.jpg REMOVE THE SWITCH FROM THE DRAWING. Cut the wireing to the foglights. Reconnect the foglights to terminal #87 of the relay. Your OEM switch will not work the foglights anymore. http://i822.photobucket.com/albums/z...Schemattic.jpg |
I'm amazed that some people still aren't grasping the fact that they can just use a simple AEV Procal to accomplish what the OP is asking. :rotflmao2:
Originally Posted by FrankTheTank
(Post 2340198)
(Post 2340218)
the factory fuse pannel will hold the fogs and running lights with no problem, i have never replaced or touched my setup in a year in a half of having them. so now hes got my option or your option he can decide for himself what he wants to do.
