foglight
Old Jul 22, 2009 | 04:25 AM
johnnyrigger's Avatar
Default foglight
I have an X with not fog lights, I got an OE bumper that has cut outs for OE fog lights, I dont care if i use a switch or the stock switch. So my question is who besides Delta makes a fog light that will fit in the cut outs? and How would i mount them in my bumper cut outs if i get some non OE fog light?
I have seen the Delta ones online, and i have also seen the OEM ones, dose N E one have pics of the Delta foglight switch? and which one is be better? thanks!!
Johnny
Old Jul 22, 2009 | 08:13 AM
golfer's Avatar
Default Foglights
I went the same way you are going. I purchased a bumper with cutouts online. I found factory Jeep fogs from Quadratech. I did not mess with the factory wiring harness that they also have. You have to take it to the dealer to have them add the fogs to your onboard computer. My stealer wanted $120.00. I simply ran wires to a switch I purchased from a local auto supply store. I installed the switch on the lower right hand side of the dash. Ran the wires to the battery. Simple operation and I can run them while using high beam. Good luck on your final selection of fogs.
