Front Speakers and Tweeters no longer work.
I no nothing about electrical wiring. Could this be due to a blown fuse. If so does anyone know which fuse I should replace?
Any thoughts would be appreciated.
Do you have an after market amp, radio, or speakers? If so I would just check the connections at the front speakers, amp, and radio.
After you check the fade of course
If everything is 100% stock...NOTHING changed and AFTER making sure the fader is ok then I woulkd think it is either a blown/shorted speaker or the amp (depending on what set up yours came with) either the seperate one or the head units built in amp. There are no fuses on the speaker outputs. IF anything changed/added then look a the wiring OR have someone who KNOWS car audio (basics anyways) diagnose it.
I don't think there is anything that you can simply fix, meaning I don't think there are any fuses to check or pull. If they all went at once, it's gonna be the amp.
Do you have a factory subwoofer?
If yes, that means you have the "premium" system and the speakers are powered by a little amp.
If you don't, that means you have the basic system powered by the factory head unit (radio).
Given that your soundbar speakers apparently still work, I'm assuming the amp or HU is fine. I'd check fade as well.
