Fuel Gauge help
Old 04-17-2023, 01:37 PM
tm2012's Avatar
Default Fuel Gauge help
2012 fuel gauge does not work and check engine lite is on. Ordered and installed a brand new fuel pump etc and it no fix. Tested old fuel pump sending unit by moving float lever and it worked as advertised. Evidently, there is a ground issue but I have zero idea where the grounding location for the fuel gauge would be and I can't seem to find a grounding diagram for a 2012. Does anyone know where it's located? Any and all help would be greatly appreciated.
Old 04-19-2023, 05:07 AM
RonandJanet's Avatar
Did you read for any codes?
Quick Reply: Fuel Gauge help
