Fuel Pump Relay Switch location
Old May 19, 2017 | 05:03 AM
Old Salt's Avatar
Default Fuel Pump Relay Switch location
I have a 2013, manual, that has shut down on the highway three times. After it sits for 20-25 minutes, it starts back up, and runs perfectly fine. I'm thinking it could be the fuel pump relay switch, however I can't figure out where it is located in the fuse box. Can someone please help? Thanks.
Old May 19, 2017 | 03:37 PM
ronjenx's Avatar
The fuel pump relay is deep inside the fuse box, soldered to one of the circuit boards.
What troubleshooting have you done that would lead you to suspect the fuel pump relay?
Old May 19, 2017 | 05:55 PM
Old Salt's Avatar
Thanks, ronjenx, based on it shutting down, occasional not starting, and occasional burn '13 has a plug in relay, and through deduction I found its location. Will see if this fixes problem this weekend, it'll get a bunch of miles.
Old May 19, 2017 | 07:17 PM
ronjenx's Avatar
Where is the relay you found?
Old May 20, 2017 | 12:04 AM
Old Salt's Avatar
K4 in the '13 box
ID:	671631   Click image for larger version
Old May 20, 2017 | 02:46 AM
ronjenx's Avatar
K4 in the '13 box
I guess I misunderstood what you were looking for.
I thought you wanted to find the fuel pump relay.
Old Apr 21, 2023 | 09:56 AM
stephenspannn27's Avatar
K4 is a removable relay for the fuel pump on the 2012
Old Apr 21, 2023 | 03:50 PM
ronjenx's Avatar
K4 is the Run/Start relay. It supplies power to the items that need power during run/start. Included in those items is the fuel pump relay inside the TIPM on the circuit board, as pictured above.
Old Apr 22, 2023 | 05:30 AM
I understand now, thank you for the info. You seem very knowledgeable, could you took a look at this thread here and provide some feedback?
https://www.jk-forum.com/forums/stoc...-353243/page7/
