Fuse #18
I'm assuming you're talking about J18 (20 amp yellow - Powertrain Control module (PCM) Trans Range) fuse? Do you have a check engine light on as well? If so, what is the code? If the fuse keeps blowing, you've got a short somewhere in your wire harness that runs your transmission.
