Fuse for fog lights
Old Mar 11, 2013 | 05:59 PM
M1222's Avatar
Default Fuse for fog lights
What fuse number in the box is for the fog lights
Old Mar 11, 2013 | 06:01 PM
ronjenx's Avatar
The fog lights and headlights have no fuses or relays.
They are controlled by solid state devices on the TIPM circuit board.
Old Mar 11, 2013 | 07:12 PM
JLsJK's Avatar
I have my fogs tripping the relay for my aftermarket fogs. There's an inline fuse next to the battery but not on the fog wire, is this safe?? I assumed they had a fuse. Is an inline fuse necessary on that side too or will it be okay?? That's the question
Old Mar 12, 2013 | 03:45 AM
JK-Ford's Avatar
For all practical purposes, you should be fine. But you can increase the margine of safety by adding a 3 amp fuse. The OE system is designed to protect a larger load than just a simple relay. The new fuse would effectively reduce the reaction time of the protective system incase of a falt.
Old Mar 12, 2013 | 07:18 AM
JLsJK's Avatar
Thank you I may eventually get around to it.
