Fuse and relays for installing a Rubi 44?
I will be installing a pair of Rubi axles in my Sahara in the next week or two and I'm trying to get everything I need together. I've read through several threads about it, but I haven't found what size fuses or relays need to be used. I'm going to order the wiring harness for the lockers and disco from Quadratec. Does it come with the needed relays? Where is the best place to tap into for power?
I'm not messing with using the oem switches or trying to connect it to the computer. I've been looking at the switches that are similar to the ARB switches at OTRATTW. He has 20a rated relays there also, as well as some in line fuses with covers.
I pick up the axles next week so I'll have to get that resistance measurement then. Is there a chart here somewhere for nominal wire size?
I had the cover off of my fuse block yesterday looking at it. It's the only clean place under the hood. I don't know if I want to risk running a wire from there and messing up the seal around the fuse block. Could I just run power from the battery and use some inline fuses?
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
