Ground issues 92 wrangler.
Old Aug 28, 2012 | 11:54 AM
Hamilton77's Avatar
Default Ground issues 92 wrangler.
I have a 92 jeep wrangler and got some ground issues, I read that I should have 3 grounds from the battery 1-to the frame ,1- to the engine, 1-to the firewall. Mine doesn't have one to the frame but it does have one to the alternator. They look to have been replaced before. Do I need a ground to the frame? And does the ground from the alternator supposed to go to the battery?
Old Aug 28, 2012 | 09:17 PM
Dieselguy3's Avatar
Everything should be grounded to each other. If the battery is grounded to the frame then everything can go to the frame as a central point then to the battery. If you do add more grounds try to steer away from the cheap grounding strips that the factory uses and go with like a 4 gauge wire to ground it all out
Old Aug 29, 2012 | 06:09 PM
Tizzyusmc's Avatar
amen to Dieselguy... i had a 1995 same issue used factory grounding burnt jeep to ground after an arch jumped from a corroded wire off the alternator....bad day lost a 9k dollar jeep and my pride
