Ground location in the back of a 2dr?
Putting an amp in the back of my '11 rubi to power the sound bar and sub. Q: anyone know of a good spot for a ground back there?
Thinking of mounting it to the back gate. Thanks for the insight.
if going to mount in tailgate... grab a file, filedown the paint till you are on metal of the tailgate and use a selftapping screw with washers to ground an Oring to that area. Ill show a picture tomorrow when I finish my tailgate speaker system.
That will be excilent for the gate. But you will still have to do something to get around the hinge.
I took up the carpet and took out the driver side trim in the back of my 2D and found a bolt in the body to mount the wire to. Did not want to drill into the sheet metal so this option was easier. However, I hid all the wiring under the carpet as well.
