Half Door Power Locks with 2012 - help please
I've searched the Forum and the Internet, and haven't found anything about this. I have the Mopar Half Doors with the Power Door Lock Wiring Harness. The harness fit my 2008 but the connector does not fit the 2012. I ordered the wiring adapter but this must be for the standard manual doors as the harness doesn't do anything that I can see when the doors are opened/closed.
I'm looking for either an adapter to allow my 2008 harness to plug into the 2012 connector or a new wiring harness that I can replace the current harness with.
This is what I currently have:
Latches
Right front 4589276AI
Left Front 4589277AH
Wire Harness
Left Front 68005005AB
Right Front 68005006AB
I just sent messages to my stealership but they are closed for the weekend.
I have found different wiring harness part numbers for 2012 but none have details if they support power door locks.
Another option I may have is to move the wires from the '08 connector to the '12 adapter connector which only has 2 wires connected to it. I'm guessing the wires will go in the same locations on the new connector.
Any help is greatly appreciated.
Thanks!
Latches
Wire Harness
Thanks!
Wow! I just got a lighting fast response back from JeepsRus where I originally purchased the half door kit from. There is a new power door lock wiring harness for use with the 2012s. Pricing is around $120 for the pair of front right and left harnesses.
Would you know if they also make wire harnesses for the 4 door, the rear two doors? Im in the process of doing the same thing you are but I have a JKU
