Headlamp 101 by Daniel Stern
Old Jan 12, 2007 | 04:11 PM
  #21
jpaddict's Avatar
There is a full write up under the "Write Up" section.
Old May 31, 2007 | 11:38 AM
  #22
captsam54's Avatar
Does anyone have pictures of their install of a Daniel Stern Harness???
Old Jan 9, 2009 | 05:49 AM
  #23
dsy's Avatar
dsy
Originally Posted by neoxxis
Hey!
Ok, I read the thread 2-3 times.
I understand that the JK has H13 bulbs/sockets.
DS says the "Philips Xtreme Power H13" will be the bulb to buy when they're on the market.
Well, they are now. And at 40$ a pair, not bad at all.
ht tp://www.suvlights.com/product_info.php?products_id=100
Did anybody install those bulbs?
Any comment?
Does it compare to some Cibié lights? (I know DS says the Cibié are pretty good...)
At 40$ I think I'll take a shot and see what it looks like...
Thanks!
There are no bulbs for the stock lamps that will come anywhere near the performance of the Cibe E-code lamps even with inferior bulbs in the Cibies.
The stock reflectors are junk.
Old Jan 9, 2009 | 05:58 AM
  #24
nclehmann's Avatar
That's right. It's not the bulb, it's the reflector. Many folks go out and get Silvania Silverstar bulbs thinking it's going to make a huge difference. While the bulb may be a higher wattage and may appear brighter than stock, the visibility is no better.
Neoxxis: Do it right and get the upgrade to Cibie/Wipac/Marchal lights (E-code) headlights and replace the crappy factory wiring for 12 gauge quality wires.
You will NOT regret it.
Old Jan 9, 2009 | 07:15 AM
  #25
smbundy13's Avatar
i was planning on getting the delta quad bar headlights that are supposedly supposed to replace the headlights in my jk.. are they worth the $150 (plus shipping) i dont really want to fool with rewiring my lights' harness if i can help it.
Old Jan 9, 2009 | 11:42 AM
  #26
Octo's Avatar
For the most part, I suspect that people are using the stock switch and wiring to trigger relays on the upgraded wiring. The relays and upgraded wiring then supply higher amounts of current to the lights.
Old Jan 9, 2009 | 11:48 AM
  #27
nclehmann's Avatar
Originally Posted by jgarner
I have a question for you guys who have upgraded your wiring harness. Are you still using the factory swithces or are you having to use an external switch?
Factory switch. One of the factory headlamp harnesses is cut at the headlamp (L or R) and the wire is connected to the relay and acts as the "switch". Since the relay doesn't draw a high current to turn it on, the factory wiring is fine. In other words, when you turn on the headlights from inside the Jeep using the factory switch, the power that would have ordinarily gone to turn on the factory headlights now turns on the relay. The relay then powers the new headlights through the new wire harness running to the new headlamps. The new headlamps are wired directly to the battery by way of the new relay with higher-quality 12-gauge stranded wire.
I hope this doesn't confuse you even more. It's very simple, but I may not know how to properly explain it in words.
Old Jan 9, 2009 | 04:17 PM
  #28
lungbutter's Avatar
Hey!
Any comment?
Thanks!
I installed those lamps based on this thread in fact back when. Cheaper than a full upgrade and much improved visibility with no blue rice-burner-ness. I can't compare them to a Cibie setup and doubt they're close but for $40 I consider this a nice upgrade. BTW, They're in an '07 that I purchased about 20 months ago and haven't burned one out yet. (Hope I don't jinx myself!)
Old Jan 11, 2009 | 02:58 AM
  #29
dsy's Avatar
dsy
Originally Posted by oO_Rogue_Oo
The back of the alternator is actually the preferred source.
Why do you say that? What would you gain there? Since that wire actually goes straight to the battery you are tapped to the battery anyway, just a little further away. Why not tap right at the battery where there are lugs set up for that. Why would you want to maybe compromise your charging source.
Old Jan 11, 2009 | 07:56 AM
  #30
garrett490's Avatar
ok...so the downfall is the stock reflectors. what happens when you buy Cibie E codes and put HIDs in those reflectors? Does that make pure awesomeness?
