Headlight Help
Old Jun 25, 2009 | 08:02 AM
djcook68's Avatar
Question Headlight Help
Okay so somehow i took a direct hit to my passenger side head lamp... the light still works and the plastic cover is just scratched, but there is a plastic ring behind the head light that broke in two...so now my passenger head lamp points up a little... so i am figuring it is the piece that you screw into to align your lights. I was wondering if anyone knew what this part was called and where i can get one from (besides the stealership), and the cost...also if i were to buy something like these http://www.quadratec.com/products/97009_301.htm, would i need to replace that part or would it come with this kit ...here is a pic out of the repair manual , i know i have the part number from the manual but i would like to be more informed about this before i have to deal with the dealer, any info would be much appreciated or if someone has a spare lying around and wants to sell pm me thanks
Old Jun 27, 2009 | 06:19 AM
MoridinTX's Avatar
It looks like you pulled that image from the parts catalog, the same one I am looking at. It seems that ring is not available separately, but as an assembly with the rear ring, reflector housing, and front ring.
As far as not getting it from the stealership, go here: http://www.moparpartsamerica.com/spl...?siteid=214583 You just need the part number from the catalog to find it easily.
Hope this helps.
Old Jun 27, 2009 | 07:01 PM
djcook68's Avatar
Yeah that was what I thought, I was hoping I could find it seperately, I think I will try to find a wrecked jeep at the slavage yard for now, I would hate to blow a hundred bucks for the setup, when I am going to end up replacing the lens and bulbs anyways. thanks for the help though
