Headlight issues
Old Dec 1, 2017 | 10:05 AM
OpenTrackRacer's Avatar
Default Headlight issues
I'm having a headlight issue and could use some feedback. I just installed Daymaker clone LED headlights. All seemed well. After adjusting and testing them I noticed that the passenger side high beam stopped working. When I put the high beams on the entire light went out. It was intermittent, than constant. I disconnected the LED and hooked the halogen back up and the high beam isn't working there either. I took the LED headlight and tested it on the bench and it works perfectly.
I know the headlights are run via CANBUS and there are no relays or fuses. Am I looking at a TIPM issue? I can't see how the LED headlight would cause a failure but the lights worked fine before I installed them so... The driver's side high beam works fine.
Thanks!
