Headlight reeplacement
Is it just me or does everybody's headlights suck. Unless the road is real dark I don't even know that there on. Whats a good replacement, any brands any suggestions.
hhhmm I thought ours were H4s but I guess not......this is cut and past from the JK service manual.
ETA: I should mention that this service manual is specifically for a 2007 jk, I don't have a clue if they have changed it since I have bought my wrangler.
BULB APPLICATION TABLE LAMP
BULB
BACKUP
3157 - DOMESTIC
921 (W16W) - EXPORT
BRAKE
3157 (P27W/7W)
CENTER HIGH MOUNTED STOP
LIGHT-EMITTING DIODES SERVICED IN ASSEMBLY
FRONT FOG
9145 (H10)
FRONT PARK
3157 (P27W/7W)
FRONT SIDE MARKER
194 (W5W)
FRONT TURN SIGNAL
3157 (P27W/7W)
HEADLAMP
9008 (H13) - DOMESTIC
9003 (H4 60/55W) - EXPORT
LICENSE PLATE
194 (W5W)
POSITION (EXPORT ONLY)
194 (W5W)
REAR FOG (EXPORT ONLY)
3157 (P27W/7W)
REAR PARK
3157 (P27W/7W)
REAR SIDE MARKER
3157 (P27W/7W)
REAR TURN SIGNAL
3157 (P27W/7W)
REPEATER (EXPORT ONLY)
WY5W
UNDERHOOD
561
BULB
BACKUP
3157 - DOMESTIC
921 (W16W) - EXPORT
BRAKE
3157 (P27W/7W)
FRONT FOG
9145 (H10)
FRONT PARK
3157 (P27W/7W)
FRONT SIDE MARKER
194 (W5W)
FRONT TURN SIGNAL
3157 (P27W/7W)
HEADLAMP
LICENSE PLATE
194 (W5W)
194 (W5W)
3157 (P27W/7W)
REAR PARK
3157 (P27W/7W)
REAR SIDE MARKER
3157 (P27W/7W)
REAR TURN SIGNAL
3157 (P27W/7W)
WY5W
UNDERHOOD
561
That's because the kit from Daniel Stern converts the JK headlamps to good quality E code Cibie headlamps with H4 Osram bulbs and a STOUT harness with relays to assure the lights get alternator voltage.
