headlight wiring not going well...
I am in the process of switching out my stock headlights with some Cibies and am having some trouble with the wiring. I have a IPF/ARB headlight harness (used the same on my old cherokee with great results). I actually had to tear apart that one to make it work for the JK. I modeled it after the setup on daniel stern's website and also used the capacitors and diodes that "dsy" suggested.
https://www.jk-forum.com/forums/show...hlight=buzzing
The problem I am running into is that I don't get a low beam with or without the jeep on. I get a high beam on, no buzzing, with the jeep on or off. The bulbs are good, the wiring is EXACTLY like the one from DS's website, and the relays are both good.
What else should I look for? I have quadruple checked everything with no answers. Help! I just want to get this over with, I have been messing with the wiring for over a week.
Impression of the Cibie install
I can tell you that this mod is the best mod for your jeep for under 250. It is a night and day difference. Ya gotta look and ride with someone to see for youself. Chris
