Hellas 500 switch and wiring questions
I ordered a couple of sets of hella's, and even though I searched enough to know how to wire up the relay, I have a couple of switch wiring questions.
First, does anyone know if a regular toggle switch comes with the hella 500's, or a three positon led switch?
Second, if its a led switch, I know that one wire goes to the relay, one goes to a ground, and the other goes to a fused power source. Am I right?
Third, if its a regular two pronged toggle switch, I know the one wire goes to the relay, but where does the other prong on the switch go? Is it unused?
Thanks for the help on these newb questions.
First, the Hella's come with a switch, which is not very good quality. You may want to consider replacing it with something nicer.
Second, you are correct about the switch wiring (relay/ground/12v).
Third, the Hella's do not have this type of switch.
Originally Posted by RedJK2
There are 3 terminals on the switch: relay/ground/12v
The swtch is too turn on power to light, so it is powered from any source you want, switched source or off the battery....flick switch, power to relay, relay closes and sends power to lights.. relay needs constant power to run lights, switch needs power to tell relay open or close...hope this helps
Ya, the switch is for letting power through to your relay. So-hook a wire up to power source, hook other end to relay, you have constant power... To turn it off just cut it right??!.... Want it off and on all the time, put a switch instead of cutting it....helping??? lol, I'm no electrician.
