Help with KC Daystar Lights
Theres a rubber hole and grommet on the driver's side of the firewall down and to the right of the steering shaft/column (whatever its called once it leaves the cab).
I folded my windshield down and ran the wire under the windshield, No problems yet... I also ran the wires under the metal compartment between the hood and the windshield. But I mounted the switch between my middle air vents. -Captain
where do you guys and gals run the wire inside the engine comparment???
