help with lights and toggle switch
Old Oct 22, 2012 | 06:55 PM
  #51
preyes44's Avatar
Originally Posted by Tizzyusmc
Good way to blow ecu...but you could...
Ok, i guess I shouldn't do that, so where??? I'm just talking about the wire that turns the lights on, I have the main power for the lights going through a relay and to the battery....
Old Oct 23, 2012 | 03:50 AM
  #52
JK-Ford's Avatar
You should use an accessory circuit for the switch power. Use either the switched cig lighter outlet. Or use a fuse tap on an accessory circuit in the fuse box.
Old Oct 23, 2012 | 04:07 AM
  #53
preyes44's Avatar
Thanks! That's what I needed to know! Much more helpful than the last comment
Old Oct 31, 2012 | 03:56 PM
  #54
Jeek.OlllllllO's Avatar
Okay im going for round two!
Old Oct 31, 2012 | 03:57 PM
  #55
Just spent 50 bucks lets see how this one goes
Old Oct 31, 2012 | 04:06 PM
  #56
rockyjk07's Avatar
Good luck!
Old Oct 31, 2012 | 04:10 PM
  #57
Originally Posted by rockyjk07
Good luck!
Thanks a buddy of my dad is going to help me out
Old Oct 31, 2012 | 05:55 PM
  #58
JK-Ford's Avatar
I'll be glad to walk you thru.
Old Oct 31, 2012 | 05:57 PM
  #59
Thank you! I will be doing it Saturday
