Help needed with install?
Old Feb 11, 2011 | 12:45 PM
jeepsta's Avatar
Default Help needed with install?
Never hooked up hitch wire harness getting the one were everything just plugs in no wire splicing has anybody done this how easy and do u have to take taillights out to get to wires? Thanks
Old Feb 11, 2011 | 12:52 PM
NJKen's Avatar
I did it and you have to take off the drivers side light to connect the harness. I had the mopar harness and it was amazingly easy with the plug and play harness. Probably took 15 minutes
Old Feb 11, 2011 | 01:00 PM
sum-daze's Avatar
Just had to take the drivers side tail light out and plug in the harness and run the wire down and out to the hitch. 15 min max.
Old Feb 11, 2011 | 01:23 PM
msells32's Avatar
Easy as pie, just follow directions! Mine was on with hitch in 30 minutes.
Old Feb 11, 2011 | 03:29 PM
jeepsta's Avatar
sounds easy will do tomorrow when light out thanks
