Help please!!
Old Jul 9, 2011 | 03:27 PM
pelonrubio's Avatar
Default Help please!!
I bought a radio from a 09 commander to put on my 07 wrangler and it does not turn on. Are they compatible??
Old Jul 9, 2011 | 06:18 PM
smokeman's Avatar
Is it a mygig? If it is, it might be a low speed bus mygig. The JK requires a high speed bus mygig. If you want to try and make it work, you could try the coasteltech mygig lockpick adapter, which I think allows a low speed bus radio to work in high speed bus vehicle. The lockpick adapter has lots of other features as well.
Take a look here: coastaletech.com/MYGIG_ADAPTER.htm.
Good Luck
Old Jul 9, 2011 | 08:15 PM
pelonrubio's Avatar
It is a mygig radio. I will check out what you said. Thanks
