Help with a stuck CD.
Old Jul 5, 2012 | 05:41 AM
bigbluejk's Avatar
go to mcdonalds and get a plastic knife. Help that mofo line up with the slot. You can buy a new radio for less than the dealer quote. I would try to get it out, but if you break it oh well.
Old Jul 5, 2012 | 01:06 PM
Ryan0260's Avatar
I would try to disconnect the battery first
Old Jul 12, 2012 | 07:14 PM
bigbluejk's Avatar
what happened with it?
Old Nov 28, 2012 | 10:35 AM
TwtPunk08JK's Avatar
I should've posted what happened after I got the CD out but I simply forgot.
I had to remove the CD player from the console, and using some tweezers I was able to remove the CD. Upon closer inspection, I found that when a CD is in the player it has two retaining clips that raise up to hold the CD in. These two retaining clips will not lower which was preventing the CD from ejecting and now that the CD is out they are preventing me from inserting a CD.
Oh well, got the CD out and burned to my iPod. So now I'm stuck to solely Sattelite radio and iPod.
Old Sep 3, 2015 | 06:26 AM
Hrdtyme's Avatar
Originally Posted by RodCyn
Also happened to mine.. https://www.jk-forum.com/forums/show...won-t-eject-cd If disc will not eject manually, use the following combination of buttons to manually eject disc: -With display open press and hold NAV button on right side -Press SEEK UP and SEEK DOWN at the same time on left side. -After button combination is pressed, disc should eject from radio. -Close display manually by pressing OPEN/CLOSE.
WOW if been at this for days until I saw your write up. Thanks it worked. Cd is out!
Old Oct 14, 2015 | 12:54 PM
COStrider's Avatar
Originally Posted by rodcyn
also happened to mine..
Mygig won't eject cd
if disc will not eject manually, use the following combination of buttons to manually eject disc:
-with display open press and hold nav button on right side
-press seek up and seek down at the same time on left side.
-after button combination is pressed, disc should eject from radio.
-close display manually by pressing open/close.
thank you so much
what a sweet trick
