HELP! where is this supposed to go?
Old Jun 1, 2011 | 11:26 AM
landoJEEP's Avatar
Default HELP! where is this supposed to go?
So I've been having some really strange issues with my A/C and power outlets. I checked fuses and everything looks good.
however, I found this just dangling under the hood.
To elaborate a little, I added coil spacers this weekend (didn't have the problem until then)..
Today on the way to/from lunch the jeep acted like this:
accelerating to 40 mph the air kicked on for a bit. slowed down and it kicked off
turned 90 deg left turn air came on straightened wheel out and turned off.
parked car and opened doors air came on and kicked off.
so can someone tell me:
1) is this wire the culprit?
2) if so where the flip does it go?
3) what else can I look into as a possible source of this issue?
Old Jun 1, 2011 | 11:34 AM
TN_JK_GA's Avatar
Default Not sure
Not sure where it goes but it looks like the ground wire.
I am not in the Jeep today or I would go and take a look.
Old Jun 1, 2011 | 11:36 AM
4fit?'s Avatar
That appears to be a ground strap. I'm guessing that could certainly cause some issues. Not sure where that one goes though. Most ground straps I have messed with in the past (non jeeps) attach to either an area of the frame or to the firewall.
landoJEEP's Avatar
yeah, I guess I should have mentioned I thought the same thing and since I was toolless (i know pretty rare) I wrapped it around the neg battery terminal.
if someone can figure out where it actually grounds to I'll go try that and report.
life sucks without a/c
TN_JK_GA's Avatar
Default Might
Might be a body ground. Reconnect it to your hood.
Old Jun 1, 2011 | 11:39 AM
2008blkjeep's Avatar
Just checked mine, goes from hood to the fire wall
Old Jun 1, 2011 | 11:50 AM
landoJEEP's Avatar
so i reconnected it to the hood. and took a shot of where it goes..
unfortunately still no a/c. I'm bummed. it's gonna be a toasty drive home. any thoughts?
Old Jun 1, 2011 | 11:58 AM
Work in Progress - JK's Avatar
That loose ground wire maybe slapped your A/C and shorted it out?
I would check fuses first!
Old Jun 1, 2011 | 11:59 AM
landoJEEP's Avatar
also the AC knob in the center (low med hi etc) if i turn it to just between off and lo I can get my a/c light to come on. but turning it to lo turns it off.
Old Jun 1, 2011 | 12:00 PM
landoJEEP's Avatar
no blown fuses.
