Help Wiring Kchilites
I am in need of some help. I purchased some 130Watt kchilites (long range) and have mounted them onto my hood. I spent forever trying to get the lights to work up before i brought the wires into my daystar lower dash panel. So long story short I was able to get them to light up to make sure my grounds were good and i unplugged them and wired everything up. Now the lights won't light up and only my daystar switch is getting power. I have tried many different places to ground and nothing. right now i it hooked up to the bolt inside of the fuse box.
Anyone have any idea what the problem could be?
Also I checked the fuse for the lights and thought it was blow but the light on the switch was lighting up. so i switched the fuse anyways and now the switch is lit up no matter of the switch is activated or not. so i put the old one back in since so that it only lights up when switched on. any clue why this could be?
Thanks for any suggestions in advance
There are two circuits one for the lights I believe its 25 amps. The other is to power the switch 5 amps, which in turn controls the relay , which controls the lights.
Ground straight to the battery neutral. I had issues finding a good ground.
Thanks for the suggestion I will give it a try when i get home. Hopefully that fixes the problem. I am still at a loss about that fuse causing the daystar switch to stay lit whether it is on or not. I think I'm just going to stick with the fuse that was already in it so it doesn't stay on and burn out.
Figured out the issue. My ground inside the fuse box wasn't solid enough so I placed it on another bolt inside the engine compartment and it worked. Also with the switch, I replaced the fuse and had the wires switched around so thats why it was lit up the entire time so now it is working as it should.
