Hi i Need a little help with my stock radio jk Sahara 2012
My radio seems to work fine but doesn't have sound on FM and AM , it works perfect on satellite , cd and Bluetooth . But on fm and am looks like normal but no sound , it can seek for signal , find an station , show it FM station but no sound at all .
I check the antenna looks fine and it's weird that it shows the station so the signal should be working fine , I unplug the battery for a couple of minutes and all its the same . I don't know if just buy a replacement on the Internet or go to the dealer to get my $ stolen . I'm concern if I buy a new one ending up with the same problem and two radios . Any idea ? speakers work with satellite radio , antenna seems to be fine because it shows the stations . Please if you have an idea let me know thanks very much |
Have you found a solution to this. Mine is doing the exact same thing you described.
Originally Posted by bad1chad
(Post 4250400)
Last time I was at the dealer they charge me 250$ to replace a "bad electronic BS take my money Sh..t breaker" . when it was a loose battery connector . It was just a loose screw and I had to do it myself . |
