HID and DRL
Old Jun 9, 2010 | 07:47 PM
wouldnt the capacitor/diode mod stop the buzzing for the hibeams and drls ?. or what if one didnt use a relay
Old Jun 9, 2010 | 07:53 PM
whpony96's Avatar
If they are Bi-Xenons they will have a relay that changes them from high to low beam. The main problem will be that the HID ballast is not designed to operate on low voltage and the ballast will buzz as well.
The best solution would be to purchase the AEV Procal and change your headlights from being the DRL's to either the fogs or the front markers.
Old Jun 9, 2010 | 08:13 PM
will the low voltage to the damage the ballasts?
Old Jun 9, 2010 | 09:55 PM
DTJK's Avatar
AEV ProCal will let you change the DRL to many different setups. Avoiding the use of the headlights for DRL
Can the ProCal be used on 2 Jeeps at the same time, the Flashpaq won't allow that. My friend has a ProCal so I'm wondering if I could borrow it and set my DRL.
Then again it probably wont work with my Flashpaq settings simultaneously, it'll probably f**k up the CPU.
Is the any other way to change your DRL?
Old Jun 10, 2010 | 10:05 AM
whpony96's Avatar
Yep sure will...
Old Jun 10, 2010 | 10:06 AM
whpony96's Avatar
No the ProCal is tied to one JK at a time.
