Hiding my GPS power cable.
Old 09-28-2016, 07:55 PM
Kellen's Avatar
Originally Posted by rob_engineer
My tomtom uses a USB plug for its power. I haven't wired it in yet, but I have a USB connector that wires into the 12v system. I plan to wire that under the dash and run the GPS cable to it. The USB connectors are considerably smaller than the cigarette lighter connectors. Just do an Amazon search for 12v USB connector. Tons available and are pretty cheap.
I can use a micro USB but then I'd loose the antenna for the traffic feature.
Old 09-29-2016, 03:56 AM
rob_engineer's Avatar
true. I got frustrated with the traffic. Steered me wrong too many times. The traffic cord actually went bad, blowing fuses. I replaced it with a non-traffic USB cable and never looked back. If I am ever in a situation when I want to have traffic info, I will use google maps on my phone which I think does a much better job than the tomtom traffic ever did.
Old 09-30-2016, 10:41 AM
Riptide9's Avatar
Originally Posted by Riptide9
I drilled a hole in the right side, down in the tray. The wire the goes down inside the console to the right of the radio and is tapped into the 12v accessory jack. To make it even cleaner I ordered a 90degree right angle micro usb charging cable so it comes straight down from what it is plugged into. Clean with no cables dangling around.
Here is a pic
Name:	Screen Shot 2016-09-30 at 11.41.34 AM.jpg
Old 10-01-2016, 02:27 AM
14Sport's Avatar
Here is a pic
Attachment 657864
Nice and clean...I like it.
Old 10-01-2016, 06:08 AM
Kellen's Avatar
Here is a pic <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=657864"/>
What did you use for a grommet?
Old 10-03-2016, 09:05 AM
Riptide9's Avatar
Round piece of foam with a slice in it.
Quick Reply: Hiding my GPS power cable.
