How to wire multiple lights to one switch
Old Mar 23, 2009 | 07:11 AM
dj4sin's Avatar
Question How to wire multiple lights to one switch
I recently installed 3 sets of the Walmart Platinum Burners lights under my jeep and was wondering how I wire all 3 sets to run off of 1 switch ? Currently I have each set running to its own switch. If someone could give me a very dummed down explanation on how to do this or even a picture would be great. Thanks !
Old Mar 23, 2009 | 07:31 AM
JK-Ford's Avatar
Bring all sets of lights back to one relay. Use your switch to turn off and on the relay.
Old Mar 23, 2009 | 08:12 AM
mjolnir's Avatar
bad idea, the relay's and fuses are probably rated for 1 set of lights.
I'd just fire all three relay's off of one switch, in other words take the "to the relay" wire off of the two switches you don't want to keep and twist them together with the same wire on the switch you want to keep.
Good luck
Old Mar 23, 2009 | 09:20 AM
JK-Ford's Avatar
Good luck
I believe that standard relays are rated for 30 amps. Even 40 amp relays are common. I have a set of those burners from walley-world and they are 55 watts. 6 (lights ) times 55 (watts ) = 330 watts. 330 ( watts ) devided by 12 ( volts ) = 27.5 amps. Certinly you would want to run #10 awg wire from the battery to the relay. And you would need to use a 30 a fuse. But you do not need the extra relays. Unless you just want them
Old Mar 23, 2009 | 11:07 AM
RedneckJeep's Avatar
Just wire the relays in tandem with fuses for each relay on the hot. Really not that difficult.
Old Mar 23, 2009 | 11:16 AM
JK-Ford's Avatar
The cheepie lights that I bought from walley-world did'nt come with relays. If it even came with a harnes. I scraped everything that came with my lights. Including the KC's. I built everything custom.
Old Mar 23, 2009 | 12:39 PM
w.wood jeepster's Avatar
three wires to one switch is pretty simple, but you will need three relays. You'll need four hot feeds, one will only need a 5 amp fuse, the other three should be rated at the capacity that each of the lights require. From the out terminal of the swithc run to each of the three relays that will trigger the lights. The other three hots to the relays, the outs from the relay to the light, then negative to the switch pole of the relay and your in buisness. The relays themselves will only draw a few amps at most. the lights however, will pull a lot and need to have their own feed each. I hope that makes sense.
Old Mar 23, 2009 | 01:32 PM
JK-Ford's Avatar
Yes, there are many different ways to do this project. Some are hard and some are easy.
Some are right and some are wrong.
Good luck
Bottom line: IT'S YOUR JEEP. Witch way do you want to do it.
Old Mar 23, 2009 | 04:59 PM
tambil68's Avatar
LOL... reminds me of the stories of Jeeps catching on fire and burning to the ground!
Like JK-Ford said "it's your jeep, which way do you want to do it?"
Old Mar 24, 2009 | 04:26 PM
mjolnir's Avatar
Sorry, I thought you already had 3 relay's and switches installed. I was just going for the easiest/quickest solution.
