I want to turn off the sub on the infinity factory system
Old Oct 11, 2011 | 09:39 AM
dasbus's Avatar
Drop the plastic panel under the steering column, it just snaps out. You will see the amp for the rear sub, just turn the volume down and your good to go.
Old Oct 11, 2011 | 11:39 AM
Bubbacon's Avatar
Originally Posted by ylojelo
My dog rides in the way-back of my 2012 JKU, so I'd like to put a rocker switch on the sub to turn it off. I figure the best way is to cut into the amp power wire, but I haven't looked to find the amp. Anyone have some ideas on the easy and/or best way to do this? [sorry to re-post,I posted this in the 'stock' forum, but thought this may be a better place]
I wouldn't even bother - the sub in the stock infinity system is crap anyway and barely puts out any sound.
BTW, the AMP drives all the speakers... not just the sub. so you don't want to cut the amp power.
If you upgrade the Amp &/or head unit, then you might consider a disconnect for the sub. Your other (and easier) is to dial the bass down when the dogs are in the Jeep.
Old Oct 12, 2011 | 03:38 AM
Rednroll's Avatar
Your easiest solution is to put a toggle switch at the speaker wire connections at the sub. There are 4 wires, that plug into the back of the sub enclosure which are the 2 outputs from the Infinity amp. (ie 2 outputs=4 wires) You would want to buy a "DPDT" toggle switch and then run both of the POSITIVE wires to the toggle switch. Essentially, you are removing power from the 2 output channels by disconnecting those output channels from the sub.
If you want the switch up front, then the Infinity amp is located under the steering column. You would need to figure out the 4 wires that run from the amp to the rear sub. Once you do that, then you would do the same as I mentioned above.
Old Nov 8, 2011 | 07:24 PM
ylojelo's Avatar
I ended up just pulling the whole sub out. I don't notice the difference. Thanks for the replies
Old Nov 8, 2011 | 07:26 PM
ylojelo's Avatar
I ended up just pulling out the sub itself. I didnt notice any difference either.
