Infinity Sub cross over point
Old Apr 24, 2011 | 05:36 PM
roxbury29's Avatar
Default Infinity Sub cross over point
Hello, does anyone know what frequency the infinify subwoofer is crossed at??
100hz? 250hz or below
Old Apr 26, 2011 | 08:07 AM
DudeManBro's Avatar
Get or make a cd or mp3's w/ test tone tracks and play them in your jeep. Switch between tracks starting at like, 70hz to 80hz, 90hz, 100hz, etc until you hear the sub get significantly lower or higher in volume. Whatever test tone track you are at where the output changes will be your crossover point. Depending on the slope of the crossover (6db, 12db, 18db) the change in volume could happen over 2 or 3 tracks in which case it will get slightly lower as you switch from track to track over a 20hz range.
Old Apr 30, 2011 | 04:09 PM
roxbury29's Avatar
Hi, thanks.. I did some research and compared several songs and subs..
