Installed an RBZ Mygig in my 2012 JKU
Old 04-18-2015, 05:43 AM
  #201
bofa's Avatar
Originally Posted by Mattk11
No not without Uconnect module. You are SOL. Buy it used on eBay or on this site if you can find one. I sold mine for $90.
Thanks, I'll have to keep an eye out for one.
Old 04-23-2015, 08:55 AM
  #202
Dmjr228's Avatar
Default Splash Screen update
Originally Posted by Flyguytki
An Update if anyone is interested. I installed a RBZ in my 2012 JKU that did NOT have Uconnect to begin with. The headunit arrived before the Uconnect wiring harness so I plugged it in and voila, everything works as advertised minus the bluetooth. The uconnect harness came a few days later install was pretty simple and low and behold the bluetooth works, no vin flash was needed. The only issue I still have is the Headunit still says Chrysler 2 weeks later. Anyone have any ideas on how to get this to change to Jeep?
thanks
You need to update the application software to get the splash screen to work on a mygig that does not automatically update. This update allows the mygig to display the correct logo on start up. I just did this on my RER (from a 2010 chrysler town and country) in my 2013 Wrangler. Once updated, everything worked perfectly.
If anyone says the can bus system is different between the 2007-2011 & 2012+ model year Wranglers, they are misinforming you. This statement is simply wrong. I switched out my head unit (as stated above) and have 100% functionality from it. The only difference is that you must update the radio manually vs the new models that update automatically.
Old 04-30-2015, 08:21 AM
  #203
darcyb23's Avatar
Originally Posted by bofa
Quick question - is there a way to add a USB port to the 430 RBZ if you do not have the Uconnect module? Not sure if any of the ports on the back could be used for that.
I wouldn't be opposed to adding Uconnect but the modules are almost as much as the 430.
lol I didn't have any luck finding a cheaper module either.
Old 05-19-2015, 08:09 PM
  #204
bofa's Avatar
Does anyone know how the Sirius transfer works when swapping units? If I am still in my "free" year does that transfer over? Do I need to call or is it just tied to the VIN?
Old 05-20-2015, 04:04 AM
  #205
LKWJeeper's Avatar
They suck for that... They count it as a separate account. If you have a paid subscription they transfer credit for the new line. So if you paid for a year you might get 8 months on the new radio. If you complain enough they should work with you.
For the "free" service they may not transfer it over or just give you a couple months free. They are real jerks over there. Customer service is terrible
Old 08-04-2015, 01:44 PM
  #206
nathonbeedie's Avatar
Default Rbz not working
It tried installing an RBZ (P05064675AE) in my 2012 Wrangler Altitude Edition and all that appeared was a faint green glow on the screen. Has anyone else had this issue? Does it sound like a bad unit?
Old 08-04-2015, 06:34 PM
  #207
ngiovas's Avatar
Are you sure the radio is from a high speed bus vehicle? A low speed bus radio will not work?
Old 08-05-2015, 04:15 AM
  #208
When I looked up the serial# it indicated that it is a high speed bus deck.
Old 11-20-2015, 04:22 PM
  #209
TurboR's Avatar
I just updated a 2010 RBZ I purchased off a forum member to the 10.10.11, before the update my splash screen had the jeep logo, after the update it now says Dodge. Unplugged the battery for a half hour. Still says dodge. Any ideas on why this happened? Anyone have issues with this?
Old 01-07-2016, 06:39 AM
  #210
suryadi's Avatar
Default doesn't work
may somebody help me
i bought 430 rb2 to replace my REQ
but when i plugged it on (rb2) nothing happened. the radio cannot ON
430 rb2 cannot work on jeep jk 2010?
P05091105AB thats the part number
help me please
Quick Reply: Installed an RBZ Mygig in my 2012 JKU
