Installing PIAA 510 lights, switch power wire
Thanks for the help guys I got it working, I spliced into a white wire with a purple stripe. I believe it's wire for the headlights because the 510's only have power going to them when the headlights have power going to them. If you think this is a fire hazard please let me know. Again thanks again for the help, Jacob
The fused wire in the kit goes to the battery?
Yeah that's the tail light wire you tapped. Make sure the wire you tapped into the tail light is at least the same gauge as the tail light wire. If it's smaller gauge (numerically higher) then you should put a 3A inline fuse in at the tapping point.
