Issues with load resistors
Old 11-14-2014, 06:21 PM
Wsullivan1221's Avatar
Default Issues with load resistors
I just installed new switchback LED lights for my parking lights/turn signals on my 2014 Wrangler. As expected, I quickly started getting the hyper flash and knew that some load resistors would solve this issue. I purchased two Aaron load resistors and installed them perfectly (to my knowledge) and still no luck. I attached the two harnesses/clips to the black outside wire and the white outside wire and connected them with the load resistor. Did I read misinformed instructions or am much worse at the install than I thought I was?
Edit: I briefly got the passenger side turn signal to run properly but it was only for a few minutes, so I assume this means they aren't faulty
Old 11-29-2014, 09:16 PM
Sierra141's Avatar
Can anyone help?
I'm on the same boat
Old 11-29-2014, 09:38 PM
Originally Posted by Sierra141
Can anyone help?
I tried a smaller wattage (from 50W to 25W) and it worked
Here's the link:
https://www.superbrightleds.com/more...istor/191/832/
Quick Reply: Issues with load resistors
