Jeep infinity sub
Hi everyone
I'm looking to swap out my infinity sub and Setup an alpine instead, does anyone know how much power is sent to the sub? Also was wondering if it's a separate amp or wired straight through the unit. Trying to keep the stock look and dont want to put my old 12's in the jeep Thanks |
Your best bet if you want to keep the factory enclosure is to still run a new amp to it with the new sub. Infiniti has an amp but it is Powered specifically for the low powered sub so it will not power anything stronger efficiently. You will notice though that the enclosure will not do well with a stronger sub since it is very small and crappy. so I just wasted time explaining that when I should have to you to just buy or build a custom enclosure if you want a factory look and throw in a sub and amp of your choice.
Originally Posted by Mangomatt
(Post 2669550)
Hi everyone
Originally Posted by Rednroll
The Infinity amp has 2 amp channels that power the sub from a separate amplifier from the head unit. Each channel has a max power rating of 50 watts, thus 100 watts total. If you replace the sub, you will want to look into getting a dual voice coil sub, so that you can connect both channels from the Infinity amp to drive the sub. If you get a single voice coil sub, then you will only be able to connect one of the 2 amp channels, thus cutting your power to the sub in half. |
I believe the infinity sub is dual 2 ohm voice coils, so you will need to get the same to extract the little bit of power out of the factory amp. X2 on a bigger dedicated sub amp
Thanks for the help |
Dump the factory enclosure and buy the JL stealth box. The factory sub is anemic. I have had 6.5" speakers mounted in kick panels play louder, lower and deeper than the factory sub.
JL stealth box
$849.....PASS |
Originally Posted by Jeep_420
JL stealth box
$849.....PASS |
Just get a good 8" or 10" sub and build your own box. $40-$50 done...
| All times are GMT -8. The time now is 03:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
