Jeep jk 2008 wont start. Can you help?
Old Aug 9, 2012 | 09:53 AM
Newjeeper78's Avatar
Default Jeep jk 2008 wont start. Can you help?
Have a 2008 jeep wrangler unlimited. Recently it has been giving me problems starting. I turn the key and I hear a click and then nothing. If I shift from park to neutral or drive then back to park it will start. I brought it to the dealership and they said its the wiring harness connection to the starter. I DON'T BELIEVE THEM. Does the wiring harness get better all of a sudden when I shift? I don't think so. If there is anyone out there that can help it would be a huge help! Thanks
Chris.
Old Aug 9, 2012 | 10:01 AM
Rich6700's Avatar
Neutral safety switch is out of adjustment. It just need the shifter linkage adjusted.
Old Aug 9, 2012 | 11:57 AM
whpony96's Avatar
Yep this is the problem!!
Old Aug 9, 2012 | 12:06 PM
steve_bk's Avatar
I have the same issue from time to time on my 07 is there any easy way to fix it or a write up to fix this. I usually while in park just nudge the auto shifter forward a bit then the it starts fine.
Old Aug 9, 2012 | 03:09 PM
profebill's Avatar
Same here. Many people have that problem. Just put it in neutral and start. That always works if that's actually the problem. There are other jk issues with starting.
