Jeep jku problem
I got a 2010 jeep jku it starts but has no gauges working won’t come out of park wipers stay on but if I unhook the battery for a few seconds an then restart it every thing works as should an drives fine but have to do that every time befor I start it any help would be appreciated thanks
Could also be a ground issue. I know once I put the third pedal to rest my foot and undid the grounds by the footwell and the wipers came on until I hooked the grounds back up. And that was with no key on.
I didn't have any codes either. Look at MAK's site for info about the TIPM. I also called and spoke with them about the problem. The thread that I used was "Jeep will start but guages blank, stuck in park, wipers won't turn off??". My problem ended up being the cluster itself. I could disconnect the battery and it would work fine for awhile until finally it just quit altogether. I was sure it was a ground or loose connection somewhere for a long time.
