JK 2012 Fan Assembly replacement
Old Jun 25, 2016 | 06:46 AM
JKTico's Avatar
Question JK 2012 Fan Assembly replacement
Hi,
I bought a Spectra Premium CF13027 Fan Assembly in order to replace the stock one. But it did not come with the motor wiring harness it just has a motor connector. The stock Fan Assembly has direct cables from the motor. Somebody can tell me if I can made by myself this wiring connection or I should use the Mopar 55058789AC (07-11 version) wiring harness only becuase special requirement?
Thank you,
