JK Headlights not getting enough voltage
Old Dec 13, 2016 | 03:32 PM
  #31
sconnell80's Avatar
Bump for any help???
Old Aug 22, 2017 | 05:21 PM
  #32
sconnell80's Avatar
Just seeing if anybody has had any luck getting the aftermarket headlights to work properly or what was used so they will. Haven't had time to mess with mine lately but will start again shortly. Gonna try and make my own harness and hardwire into my factory headlight wiring. That way I dont have to worry about the jump connectors they use.
Old Aug 22, 2017 | 06:20 PM
  #33
jstikel3's Avatar
I had the same issue with multiple LED headlights, adding resistors etc. Seems like it is only an issue for some 2007's. I ended up wiring up the headlights to 2 relays (1 for LB and 1 for HB) and have a 3 way switch to control them. Yes it sucks it doesn't run off the factory controls but having some real light to see at night is worth it to me.
Old Aug 23, 2017 | 05:42 PM
  #34
sconnell80's Avatar
I have thought about that but would rather leave everything stock. Ill figure it out eventually, just need time
Old Sep 3, 2017 | 05:48 AM
  #35
jstikel3's Avatar
Keep me updated if you figure something out I'd rather have mine run off the stock switch also.
