JK light bar?
Old 01-08-2009, 06:39 PM
  #21
JKBenB's Avatar
I know this is digging up an old thread... but did you get this bar made and installed yet? And how much did it run you? I'm loving the low profile nature of it...
Thanks.
Originally Posted by HITMONEY
A place in the UK, Wickford, Essex, England, called FTE...
I emailed them a few times about making one for the JK, the one in the picture is for a TJ. I never heard back from them so I asked Bulldog fab to make it.
Shipping from AZ should be alot cheaper then from the UK.
Old 01-08-2009, 06:59 PM
  #22
armycop's Avatar
They are making a "Rota Bar" by Carr. It is on 4wd.com for $149.99. I like it!
Old 01-08-2009, 08:52 PM
  #23
JKBenB's Avatar
Not bad... any clue if you can mount lights to the underside of this bar though? Thanks!
Old 01-08-2009, 09:18 PM
  #24
Sponsoring Vendor
Off Road Evolution Rep
serveapurpose's Avatar
Something my brother in law and I are planning on working on this spring. It will be modular so that the small basket can be removed quick and easily if necessary. Has a similar look to the KMA fab design but the lights will sit lower, the basket will conect using factory mounting points for the hardtop and door surrounds. It can be used with the top off ( obviously) or the soft top on with some minor modifications to the soft top via a marine shop. Perfect for those with a 2dr. and a need for a little extra storage space on longer than a day trail runs or camping trips.
Old 01-08-2009, 09:23 PM
  #25
armycop's Avatar
If rotates down for clearance, so probably not. I am not sure, maybe 4wd.com would have more info if you call them.
Old 01-09-2009, 04:58 AM
  #26
mmcan's Avatar
Originally Posted by Ryanm
The KC lite bar doesn't interfer too much, you barely notice after a couple hours behind the wheel.
Ryanm,
I pm'd you about your awesome Jeep.
More Pics and Info please!!!
Old 01-09-2009, 04:59 AM
  #27
mmcan's Avatar
AZ Bulldog (Bulldog Fab) is in the process of making something like this for me without lights. I plan to mount the Xmitter Light Bar to it, but you could mount any other light you like to it as well. I wanted a low profile one that didn't add any height to my rig.
PM him and I am sure he will make you one as well.
I like this a lot!
Post pics when you get yours done with the Xmitter's please.
Old 01-09-2009, 05:15 AM
  #28
Littlejon's Avatar
I like the look of the Carr light bars, but I don't like that they are only designed to hold a total of 4 pounds of lights. All the lights I have been looking at are 4 pounds each.
Old 01-09-2009, 05:46 AM
  #29
ranwitscissorz's Avatar
4 pounds? Is the bar made out of plastic?
Old 01-09-2009, 06:04 AM
  #30
adgraybda's Avatar
Originally Posted by marlettx
i like this bar
how much for one of these?
x2? N2Rock, how much would one of thoes be? Is that in production or a custom work
Quick Reply: JK light bar?
