JW Speaker J-Series installed
There's a harness, so no need to splice if you don't want to...
I believe it was this one:
https://www.headlightrevolution.com/...?gfid=p352-c12
Agreed, super easy install. I still tell my wife "I can't believe these lights".
I am a bit bummed to read that some of you are experiencing issues. I have the headlights and fog lights with no substantial problems.
I used the harness for the fog lights.
I also use a rubber end cap for a bolt to cover the photocell on the dash so my headlights are always on. I hate driving through a tunnel to have them come on, then go off again. So, no issue there with the fog lights being dimmer.
The one issue I have, is going from high to low has a < second delay in dimming. This was something I knew about beforehand, so I was prepared.
Best upgrade on any vehicle I have ever owned!
Flickering
Wanted to ask again if anyone had any issues with the J series fogs flickering? Mine is the faintest flicker and ONLY when engine is running.
JW is giving me no answers, I thought it was the harness I used so immediately spliced/soldered the OEM fog harness for a direct connection, same flicker!
I am out of ideas, can anyone help?!?
Cheers,
G
Cheers,
G
Wanted to ask again if anyone had any issues with the J series fogs flickering? Mine is the faintest flicker and ONLY when engine is running. JW is giving me no answers, I thought it was the harness I used so immediately spliced/soldered the OEM fog harness for a direct connection, same flicker! I am out of ideas, can anyone help?!? Cheers, G
