Kicker sub in stock 2008 2 dr
REPLACED THE STOCK SUB WOOFER WITH A 2061CVR82 Kicker 10CVR82 8" 2-ohm DUAL component subwoofer. HAD TO USE SOME BLACK WEATHER STRIPPING 1/4'' THICK TO SEAL AND SPACE OUT. ALSO MOD FACTORY GRILL TO FIT. DAMM WHAT A DIFFERENCE, I ALSO CHANGED THE OTHER DASH AND SOUNDBAR SPEAKERS WITH THE MOPAR FACTORY KICKER REPLACEMENTS, WHICH WAS A HUGH UPGRADE OVER THE STOCK CRAP.
BUT THE KICKER SUB WAS A SURPRISE!!!!!!!!!! ORDERED THE SUB FROM Crutchfield .
SORRY I DIDN'T KNOW IF IT WOULD FIT OR HOW IT WOULD SOUND SO NO PIC'S.
SO ANYONE WHO ONLY WANTS TO SHELL OUT ONLY $100.00 FOR A SUB, TO MY HEARS, GREAT UPGRADE!!!!!!!! HAVE FACTORY MYGIG AND FACTORY AMP. IT ROCK'S!!!!!
HOPE THIS HELPS!
HOPE THIS HELPS!
Re: Kicker sub in stock 2008 2 dr
Did you have to mod the cover? Does it still fit in there? Did it have matching holes to seal if down? Or did you have to drill new holes?
Sent from my PC36100 using Tapatalk
HOPE THIS HELPS!
HOPE THIS HELPS!
WHY ARE YOU YELLING!!!!!!!
Kicker Sub to replace factory infinity sub
Can you post some pics of the grill cover please? I want to see how you modded it to fit. I assume the sub has 8 holes instead of the factory sub having 6. Is that a Jeep thing or would a different Infinity sub also have 6 holes? I want mine to keep the factory look...
Yeah man it would be helpful ... if you had pics of what you did to the sub. So youre telling me that you used the factory 8' sub woofer housing and replaced it with a 10' kicker in the same sub woofer housing?
