Led lights
Is anyone running eBay light bars I found a company called egrills auto there selling a kit for 600 .. Just curious if there any good . I'm not looking for top of the line or to spend thousands
Combo 50" bracket for Jeep JK (2007-present) and 50" 100 LED bar
Tons of info, check the search
Otherwise, it probably isn't a bad deal, and you get everything all together.
You can buy a 52" light that probably came right out of the same factory for $225, the Eautogrills mounts for 114, an Ebay harness with switch for $18, and have enough left over for a set of Rigid Duallys. Otherwise, it probably isn't a bad deal, and you get everything all together.
I have the eautogrilles LED bar on my jeep. I have a love/hate relationship with it.. it has sheared the bolts out of the light mount three times and lost the light on the hood. Banged up the paint and dented up and bent the light. Now Its packed with jbweld to hold it in place. And it whistles so loud I couldnt drive it over 55 without going deaf.. I figured out a way to calm the whistle by using 3m edge molding (search under my username and you'll find the thread).. All in all, the lights are a good deal if you're willing to put in a little work beefing up the bolts in them. way cheaper than the Rigid LEDs that are already beefed up.
