Led reverse bulbs
Old Nov 21, 2012 | 08:01 PM
Canibeat's Avatar
Soooooo so do you need resistors to do what the OP has done?????? Thx
You only have problems when changing blinkers with the wrong bulb. It's just built in the circuit that if you have less resistance i.e a burnt out bulb (open) the blinkers blink faster (hyper blink) to inform you to change the bulb.
Old Nov 21, 2012 | 08:04 PM
robsjeep9's Avatar
JK-Forum Ambassador
Ok thank you
Old Dec 5, 2012 | 06:03 PM
n3tfury's Avatar
Will this work with a 2012? Really nice and bright. Love it.
Old Dec 5, 2012 | 06:06 PM
robsjeep9's Avatar
JK-Forum Ambassador
Got mine.... Big difference
Old Dec 8, 2012 | 02:02 PM
Kfavorite's Avatar
Just purchased some too. Interested to see how well they light up my rear lol
Old Dec 9, 2012 | 08:29 AM
NY2013JK's Avatar
Just ordered a set as well...
Old Feb 19, 2013 | 04:53 PM
Dr. Satan's Avatar
I was intrigued with the reverse LED's. I bought some 3157W bulbs from autozone made by jamstraight (coincidence that the op of this post is JAM85?). $27.99. I changed just one first for comparison purposes. Ehh. Then waited until dark and checked again. Ehh.
It's an easy swap, 5 minutes max. I would describe the light as "whiter". I'm not sure it does much for rearward visability. I put them in my 08. I also have a 2012 so when I have 2 helpers I will park both jeeps side by side to compare.
Maybe these are low quality bulbs but I kept my incandescent bulbs and depending on the results of the side by side those may go back in? I guess I would only recommend these if you already had to replace a bulb anyway. Other brands may be better?
Old Feb 19, 2013 | 05:10 PM
Fugg it's Avatar
nice! I tried those too but they weren't as bright ss I wanted. ended up doing some led light pods and tapped into my reverse lights last night
Old Feb 19, 2013 | 05:15 PM
tribulation138's Avatar
the ones from autozone are junk and cheap. you needs to get the ones i got from ebay
Old Feb 19, 2013 | 05:32 PM
Fugg it's Avatar
figures, those were the ones I bought too and don't look nearly as bright as the OPs are from eBay. thinking if swapping all my rear bulbs with these. anyone know the brake light/turn signal number bulb?
