LED rock lights from china (20x SMD 5050) help
Old 08-11-2014, 10:44 PM
atxbro's Avatar
Default LED rock lights from china (20x SMD 5050) help
They took so long to get here i forgot i ordered them. Anyone know a thread about install of these? I ordered a daystar switch as well. I'm in a 2 door JK sport. Thanks
Old 08-15-2014, 10:54 PM
Jp3792's Avatar
Do you have any electrical back ground?
You will need:
Fuseable link ( 15 amp ) is generally okay with leds
A relay
A toggle switch and wire
Grommeting ( big enough to go around your wires)
If your unsure you can buy premade wiring harnesses. But in my experince the relays and links are horrible and cheap. So make sure you get a decent one. Grommeting isnt a bad idea either to protect your wires from elements.
Old 08-15-2014, 10:56 PM
Jp3792's Avatar
You will need:
A relay
Put it some where its protected and not near any heat.. can you tell me what they use to mount? 3m?or 2 bolts
Quick Reply: LED rock lights from china (20x SMD 5050) help
