Light Bar Issues
Old 07-21-2016, 03:01 PM
alecwaller1's Avatar
Originally Posted by 14Sport
Sounds like a broke light bar.
Are there separate wires on each end of the bar for power?
No just a + & - from one end
Old 07-21-2016, 03:08 PM
nevillebartos's Avatar
Sounds like it could be bad to me. You might as well recheck all wiring though, you could double check it by cutting the wires just after the fuse (from the lightbar, for safety) and touching them directly to the battery.
Old 07-21-2016, 03:12 PM
14Sport's Avatar
The bar is getting power since one half lit.
Old 07-21-2016, 03:15 PM
So half the bar is broken?
14Sport's Avatar
Sure sounds that way. Do you have a warranty?
Old 07-21-2016, 03:25 PM
I bought it from a good dealer on eBay. I'll try to get in touch with them but I think So.
Old 07-21-2016, 03:36 PM
14Sport's Avatar
You should be good then. It's unfortunate and I feel bad for you. All that work only to be disappointed when you hit the switch. But on the bright side when you get the replacement it will be the second light bar you've installed.
Old 07-21-2016, 04:25 PM
Thanks for all your help anyways! I'll send you a picture when it's all said and done
Quick Reply: Light Bar Issues
