Light Question
Old Sep 11, 2007 | 06:12 PM
NoobJeeper's Avatar
Default Light Question
I am making a bumper for my jk, and I was wondering if I could use the same wires/connections on the stock fog lights and put a set of KC's in place??
explain please...
Old Sep 11, 2007 | 06:15 PM
Robar's Avatar
No. The KC lights are most likely a higher wattage than the stock lights. You could use the stock switch to activate a relay to power the KC lights, but you could not wire them directly.
Old Sep 12, 2007 | 07:12 AM
Bodo's Avatar
What Robar said. I just installed a set of Hella's on my bumper. I left all the factory wiring and connectors there, but I did splice into the white/orange wire on the passenger side to switch the relay on using the factory fog switch. I then ran new wires (12ga) for the power and ground wires.
